Moving a South Bend Heavy 10
Results 1 to 15 of 15
    Mar 2017
    North Carolina
    Default Moving a South Bend Heavy 10
    First post, first lathe. Picked this up at an auction in NC. CL8187zb bed length 3.5 serial number 20575 R. Flame Hardened bed.
    I read through the Heavy 10 moving threads but have a question since I didn't see it covered. Since they are notoriously top heavy according to posts, I was going to attach a couple of 4x4's lag bolted using the through holes from front to back and make them stick out a foot for stabilization and to get it up for the forklift. Once up off the floor, the rigger can put it on my trailer with a forklift and I have a forklift quick attach for my Kubota (1600 lbs + capacity).
    The question is, can the forks just lift the lathe from below the cabinet with no damage to the cabinet? I've seen where it's pretty heavy duty sheet metal according to comments but I didn't get a chance to check the thickness of the cabinet and I wont have access to the machine till Friday right before I have to load it.
    Plan B is to first run 4x4's along the front and back (parallel to the front) bolted or lagged to the frame, then put 2 4x4's from front to rear at the ends for stabilizers and to get it up off the floor. Then the lifting would be done under the 4x4's and not on the cabinet but they'd be flush with the bottom.
    Thanks!
    Jul 2011
    Navasota / Whitehall Texas
    3,407
    2508
    1856
    Sling strap through the bed web with carriage and tail stock all the way to the right.. Forks above the lathe is the safest way..
  3. Likes ncbuckeye liked this post
    Aug 2010
    Illinois
    25
    First I'm going to give you an advice. Don't tell anyone here how much you paid for it because they will trash you for not paying enough to the auctioneer.
    Now about the move. I just purchased SBL CL0117C at auction also. Like swatkins said the safest way is to put a strap and lift the lathe with forks over the machine but if the lift truck operator knows what he is doing then you will be safe with forks under cabinet also. What we did is sling strap through the bed as close to spindle as possible and lift truck operator lift the machine high enough to clear my trailer. One guy was holding machine on the opposite side of spindle to balance it. Then I just backed up the trailer under the machine and he lowers it on my trailer. Basically I don't want him to drive around with my machine hanging on his forks.
    BTW great lathe. Hopefully it will be fully functioning.
  5. Likes ncbuckeye liked this post
  6. #4
    Mar 2016
    New Jersey
    919
    16
    179
    I hoisted mine out of my truck basically the same way, using slings and a chainfall. Balance point is pretty much under the spindle nose. Don't run the slings across any handles and use some blocks of wood to keep it off the lead screw if needed.
  7. Likes ncbuckeye liked this post
  8. #5
    Mar 2017
    North Carolina
    Thanks for all the advice guys. I'll get a feel for the rigger and see what he says too and make a decision then. He already moved about 10 lathes out of there so he'll be in good practice. :-)
    I did test it out pretty good before I bought it, all the feeds worked. A couple chipped teeth on the head gears and some backlash in the cross feed but other than that seemed pretty good.
  9. #6
    Aug 2007
    5,201
    1130
    1010
    Quote Originally Posted by Pysiek View Post
    Just don't gloat about how your screwing your boss out of decent tooling for your benefit. That's what you did.
    Auctions have nothing to do with deceit.
  10. #7
    Aug 2010
    Illinois
    25
    Quote Originally Posted by traditional-tools View Post
    I apologize.
  11. #8
    Dec 2007
    Central Ohio USA
    3,552
    33
    1576
    traditional-tools wrote: "Auctions have nothing to do with deceit. "
    Sadly, lots of stories on here to the contrary, but that's a bit OT.
    To the OP -- agree with the chorus of 'lift from above'. Balance issues can be addressed with a ratchet strap from the heavy end to the sling point, to replace a "human in the drop zone" balance helper. Your stabilization timbers will help steady things as you go down the road, though. Through-bolting them is best, with counterbored holes on the bottom side, so they can't roll in emergency braking/maneuvering. Take it slow in the loading and you'll be fine. Minimum 2" straps for hold-downs -- no 1" baby straps.
    Chip
  12. #9
    Aug 2007
    5,201
    1130
    1010
    Quote Originally Posted by Chip Chester View Post
    Sadly, "auction" has become slightly abused with the advent of ebay. But what I was pointing out was that there is nothing wrong with getting a great deal on equipment, I've got some of what I consider great deal myself...others I've paid fair value on machines I wanted.
    Anyway, let's let this die, Pysiek posted a wonderful lathe he got at auction in another thread. Looks very nice, IMO. He should focus on that one and not get castironitus...another problem that many of us have when collecting machines...myself included.
    I have a Heavy 10 I've moved around my yard and garage, and I've felt comfortable putting forks under the cabinet, but that was on a tube leg frame. I also used slings and hoisted from the top, and that works well also. I've also taken the lathe off the cabinet and moved it and believe it or not, it's way more off balanced when off the cabinet, IMO. I can muscle the cabinet around my shed on concrete floor by myself.
    A forklift is always my first choice, but if you added some timber along the bottom you could slide it on pipes pretty easy. These machines are so light that as long as you don't tip it over, there is probably no best way, as there are so many ways to skin this cat.
    It is always safe to go from the top with slings under the entire machine if possible.
  13. #10
    Sep 2009
    Apex, NC
    1,124
    531
    The extra stabilization is good on front to back, they're top, and front heavy and thus want to tip forward (usually) or backward. If you have it bolted to 4x's (I also usually screw/nail some perpendicular 2x blocking to the skids for extra measure) you can also move it with a pallet-jack (with some blocking if required). I move a lot of stuff with oversize skids (machines always lag-bolted) made to accept a pallet jack, and a rollback wrecker (never have to pick anything up more than an inch or two, and that winch on the wrecker is handy). To get things up on the skids, if a forklift isn't available, I have a boxfull of 6x6"x3/4 and 1/2" thick plywood shims, and with a prybar,jack, etc, slowly shim each corner up (one shim at a time) to get the skids underneath (slow but safe and not too strenuous). Good Luck, Cheers.
  14. #11
    Mar 2017
    North Carolina
    Well, thanks to all the great advice I don't think this could have been easier. They pulled it out of the toolroom with the forks under the bed, but they strapped it to put in the trailer. He was at first going to put the strap around the bed but I talked him out of that when i saw it might put a lot of pressure on the lead screw. He didn't seem to think it would hurt it but I may not have lifted a lathe before but I knew that was a bad idea. He lifted it from one of the cross pieces inside the bed. It was a tad off balance but was fine. When I got it home I used 2 of the cross pieces and it was perfectly balanced.
    I had decided before I got there I was going to heed the advice from here, but after getting a closer look at the base, my proposed method would have never worked anyway. You can get the forks underneath the bottom front without putting it on blocks but the back of the cabinet goes all the way to the floor blocking you from picking it up level. You'd have to play a bunch of games with some wood blocks to level it out.
    southbendheavy10-2-7-.jpgsouthbendheavy10-3-7-.jpgsouthbendheavy10-4-7-.jpgsouthbendheavy10-6-7-.jpg
  15. #12
    Dec 2007
    Central Ohio USA
    3,552
    33
    1576
    Glad you got you, and it, home unscathed. Now make some chips.
    Chip
  16. Likes ncbuckeye liked this post
  17. #13
    Sep 2004
    Fort Worth, Texas
    2,003
    172
    160
    The last couple I bought (Logans) we forked them between bed and cabinet.
    That worked just fine.
  18. #14
    Sep 2009
    Apex, NC
    1,124
    531
    Congrats, "no excitement" is always good. If you need a mill or another lathe to work on your lathe, and you're nearby, feel free to PM. That's a heavy-duty grinder you have there for ballast. Cheers, Charles
  19. #15
    Mar 2017
    North Carolina
    [QUOTE=car2;2941474]Congrats, "no excitement" is always good. If you need a mill or another lathe to work on your lathe, and you're nearby, feel free to PM. That's a heavy-duty grinder you have there for ballast. Cheers, Charles
    Thanks Charles, I may take you up on that. I'm not far from Apex. Yeah, the grinder is a beast. It's a Hammond model OK-10. The specs say it weighs 400 lbs.
