lost_cause
- May 18, 2010
- Maine, USA
My "I took my lathe apart and all the pieces are in a box - what do I do now" thread
no, it's not as bad as it sounds - nowhere near it really. over the last week or i've been debating what to do with my south bend 9b that i'm not using. i figure no matter whether i sell or keep it, it wouldn't hurt to to tear it apart & clean & inspect it. if i keep it i know where things stand, and if i sell it it will let me think about how much i am willing to bend on the price.
i have a 4-pulley v-belt setup and a v to flat motor drive belt, and both belts were pretty well ripped and cut through in spots. the original belt from the lathe to countershaft had a fixture crimped on the ends so it could be unpinned and taken off. i'm replacing it with a one piece belt since i wanted to pull the shafts and check the bearing anyways. i took the countershaft out & it had some galling present on the shaft & in the races, but nothing more than many of the pictures & videos i've seen on the internet. when i took the spindle out i actually got a surprise.
http://i908.photobucket.com/albums/ac286/lost_cause_photos/lathe/IM001714_zps072d919e.jpg
http://i908.photobucket.com/albums/ac286/lost_cause_photos/lathe/IM001715_zpseb12f0f1.jpg
the lathe had seen a lot of neglect somewhere prior to my getting it five years ago. the ways had multiple things dropped on them resulting in dents and there was some galling along the length of the ways from lack of oil ann failing to remove foreign material. lots of surface rust. bush-league motor and countershaft alignment and mounting system... i wasn't expecting much when i pulled the spindle, but what i got is as clean as i could imagine. the spindle & bearing journals in the headstock are as close to perfcet as i could imagine.
at this point my only question so far is what's the best way to clean the remaining baked on oil & crud from the polished surfaces of the spindle? it doesn't want to come off with a rag & wd-40, and i tried scraping with a piece of plastic but that isn't working either. i really don't want to use any sort of abrasive, but i don't know what to try next. any suggestions?
