jgrady1982
- Aug 7, 2010
- Cleveland Heights, Ohio
Hello,
I am new to this site, but what a great website! I have been a member over at ADVrider for about two years now, and rebuilt a 1986 XL600R and I am currently turning a 1975 KZ400 into a bobber. However I was recommended by some of the machinist people to this place. And wow, what a great site this is.
Here is the story, my Dad owns a machine shop here in NE Ohio and I grew up working there all through college and then for the first part of graduate school. I did a little of everything, but I am not going to lie, mainly my job was deburring and sweeping! Lots of sweeping. I have been looking for a lathe to make some various parts for my motorcycle builds (i.e. wheel spacers, stuff like that) and kind of was set on a SB lathe. I emailed and called a guy last weekend about this lathe. He stated that his Dad bought it and him and his father were in the process of restoring it. So I went and looked at it and, yep they were not lying, everything was apart and a fresh coat of primer was applied in some places. From what it looked like, they were just "freshening up" the lathe and not really doing a total tear down and cleaning. But whatever, I bought it. I thought to my self, "self...you can put together a motorcycle, why not a lathe?"
Hopefully I don't let myself down!
The guy knew that the lathe was a 10" South Bend...but that was it. He told me that the motor was 3 phase, which is going to be an issue since I do not have a 220 3 phase in my garage.
Okay so here is my plan...
1. The threads on the lead screw near the middle of the length of the lead screw are pretty thin, I am thinking about replacing the lead screw...what do you guys think? Where can I buy a new lead screw for this machine? Also, on the "apron" (I think it is called the apron) The two half nuts that encompass the lead screw appear a little think as well. What can I do about this? Again sorry for my ignorance.
2. Obviously tear down and paint. I have heard that Sherwin Williams oil based works great...thoughts?
3. You will see the motor in the pic, it is a GE 3 phase motor. However that's all it is, just a motor. It did not come with a mounting bracket to mount the motor to the "frame" of the serpentine belt drive. What can I do about this? I have heard about a VFD, who sells these things? Or should I just go with a 1/2hp 110V motor from Northern Tool or something like that? Will the forward/reverse switch still work with a 110V motor?
4. The ways are in pretty rough shape. Well as far as I can tell they are. I am going to take some pics of those so that somebody can tell me what I should do with them. It seems like the roughest part of the ways is the way on the operator side of the machining about 2 inches from the chuck. It is almost non-existent. Pretty bad. What can be done with this?
Other than that there is really nothing else going on with this. I did start to take apart the head stock and quick change threading gearbox. I have a parts washer, which did an awesome job!
Here are the pics, if I forget anything I will post another post.
Jack
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2239.jpg
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2240.jpg
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2241.jpg
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2246.jpg
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2243.jpg
Motor minus the mounting bracket...
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2249.jpg
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2225.jpg
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2231.jpg
On this pic you can see a small broken piece of metal just below the top handle on the top of those bearing thingys...(sorry I have no idea what those are called) and between the two upper most gears in in the picture. What was that? I would love to order another one on ebay, buy I would love to know what it is called first!
http://i477.photobucket.com/albums/rr139/jgrady1982/south bend lathe/DSCN2236.jpg
One last thing...how do I get a manual for this machine? I have searched on google and came back with nothing.
Thanks again,
Jack
Jack
Thanks again,
Jack
