mooseracing
- Apr 12, 2013
- MI
I was just handed down this lathe that has been around awhile, it seems like C model but the serial number is throwing me for a loop if I am reading things correctly. Here are some pictures:
I think the cross slide handle has been replaced as well it moves opposite its numbering. The power feed has been modified to get it slower. There is also some bracket on the back side of the cross slide. Alot of this was done at least 30-40yrs ago before my dad had the lathe.
I was going to replace the rubber belt (that drives the spindle) as it is old and dry but I figured I would replace the wicks along with checking the spindle tolerance if I had to take the spindle out. When I put the oil in the cups that are about at spindle level, not the top ones, it just seeps out quickly as well.
