Here are some pictures of the new switch internal connections and the schematic I have found on the inter web.
I have traced it all through and something is strange (either me or everyone out there that uses this switch.I suspect me). If someone can explain where I am going wrong I would be truly thankful!
The thing is it seem this schematic switches the polarity of the run winding(s) not the start winding(s).
Let's say L1 is hot & L2 is neutral.
With the switch to the left:
Run winding:
L1 connects from Lug6 which bridges to Lug5. Lug3 & lug5 are permanently connected. Next it travels from Lug3 to Lug4 where it enters the Run winding clockwise. The other end of the run winding is connected to lug1. From lug1 it finishes up at lug2 whites is L2
Start winding:
L1 connects to lug6 which bridges to lug5 where it enters the start winding counterclockwise. It passes through the start winding, captor & switch and ends up at lug2 which is L2
With to the right:
Run winding:
L1 connects from Lug6 which bridges to Lug5. Lug3 & lug5 are permanently connected. Next it jumps from Lug3 to lug1 where it enters the run winding counter-clockwise. The other end of the run winding is at lug4 which is switch connected to lug2.
Start winding: It follows exactly the same path counterclockwise as in the left mode.
