Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By OldMachinist
Thread: need tool ID
    BuzzyB's Avatar
    BuzzyB is offline Plastic
    Feb 2012
    Eastern MA
    47
    Default need tool ID
    This came with my 9A. I have no clue what it is. End is a MT3 taper with a tang. There is no apparent way to clamp anything into the slots. End has a small dead center. It was commercially made, as there is a manufacturer's stamp on it. Any ideas what it might before?
    steve-l is offline Cast Iron
    Mar 2012
    Geilenkirchen, Germany
    366
    Your spindle is MT3. Using a dead center in the spindle and dead or live center in the tailstck along with a face plate on the spindle thread allows the use of a dog to drive work between centers.
    phantom71's Avatar
    phantom71 is offline Hot Rolled
    Mar 2009
    Alabama, U.S.A
    610
    Yes, it can be used as a dead center in the spindle but I want to know what it was originally made for, that is a damn good question.
    Mitch
    edkolt is offline Cast Iron
    Mar 2010
    NW Ohio, USA
    486
    It is the original "Widget". I would hang on to it if I were you.
    Ed S
    BuzzyB's Avatar
    Feb 2012
    Eastern MA
    47
    Yet, it is a widget. Would be nice to figure out what it might have been designed for. Previous owner didn't know either.
    S_W_Bausch is online now Diamond
    Jan 2010
    Indianapolis, Indiana, USA
    4,595
    Someone should offer $10 for it, that should make the OP nervous about saying yes, cause it "might be worth more".
    So, in the intervening years from now to the OP's demise, it will sit on the shelf in his shop.
    His heirs will put it on a folding table at the garage sale, and somebody will buy it for a dollar, then stumble onto PracticalMachinist.com, and post a "Can anybody tell me...." thread.
    OldMachinist's Avatar
    OldMachinist is offline Cast Iron
    Mar 2010
    Nashville, IL USA
    322
    It's the shank portion of a Clark adjustable gasket cutter. Here's a picture of one of mine.
    ADFToolmaker likes this.
    BuzzyB's Avatar
    Feb 2012
    Eastern MA
    47
    Wow! I never would have figured that out in a million years. Gladly would I sell it for $10! I can't see that I would ever use this half tool. It will not work in my drill press. It has sat in this lathe bench for over 40 years, likely unused and missing the cutting arms.
    k3vyl is offline Hot Rolled
    Feb 2008
    newark DE USA
    658
    The real question now is do you ever cut gaskets.You can make the arms and install new bolts etc.Most regular gasket cutters only do one diameter at a time.Thats a clever one,it does both steps at once.You could turn down the MT3 shank to fit in the chuck of the drill press.
    Mar 2010
    Nashville, IL USA
    322
    A few examples of the Clark line of tools.
