HELP! Redoing 10L lathe. I removed wires from drum switch, marked wires-noted locations. Numbers came off of leads during cleaning. I am not familiar with these older GE Instant start motors. The motor is single voltage, 115 volts, 3/4 hp. The stud terminals are marked numbers 1-5. This motor has a relay and a rotary switch. Lead # 5 was wired from L1 directly to the motor. Does anyone have a wiring diagram of motor and drum switch they can send me please? Last thing needed to fire up machine.
Thank you.
Thank you.
