rigster
- Jun 10, 2012
- Boise, ID USA
Sorry this post maybe a little cryptic. I am stuck in a hotel and the only Internet I have is my phone. I have a 1940 SB 9a lathe that I bought over a year ago. I welded up a table for it and I am mounting the lathe to the table. I have been using the layout dimensions from the "Army 9 inch lathe technical manual". I know the page with the dimensions is titled 10-k horz drive but its the only dimensions mentioned I could find. The dimension called out from the rear hole of the lathe to the drive unit center pivot bolt is 15.75. Well after mounting the lathe and drive unit, The switch arm assembly with the flex conduit cable won't mount on the lathe. The drive unit is too far back. When I got the lathe the gentleman mentioned the belt had been shortened as well as the turnbuckle rods. I would like to mount the lathe as close to stock as possible. I initially thought the belt, turn buckle rods and the switch assembly flex cable had been shortened. But I found a length called out on the flex cable in the army manual. It appears the flex cable has not been shortened.
Does anyone know the correct distance to mount the drive unit? The correct length of the turnbuckle rods ? Also the correct belt length (I think ) 53.5 inches. Is that the circumference of the belt or is the circumference less due to the overlap in the glueing up process? When I get the lathe mounted I will probably go with a serpentine belt. First things first. BTW Being a machinist or welder is not my day job. Thanks for any help or guidance.
