herman pahls
- Dec 2, 2014
I just purchased a South Bend 9" and from what I have learned on line it could be a Model C.
The longitudinal feed is powered but the cross feed is not.
The jack shaft is not adjustable with a break over center device to set the flat belt tension.
The motor appears to be a 1/4 horse and seems to be on the weak side.
The lathe came with 10 extra gears which I assume are screw gears to change the speed of the tool apron.
I have several questions about this lathe that I am sure this forum can help me with.
1. I want to make the jack shaft adjustable with a quick adjust break over mechanism to set the flat belt tension.
I could bolt the existing jack shaft stand and motor onto a hinged plate and fabricate an adjustable turnbuckle break over device.
The only place I can see on the lathe to attach the turnbuckle device is using the bolts that hold the the spindle bearing caps.
2. What horse power motor should I consider using, to upgrade the current possibly tired or underpowered motor?
3. The lathe came with one idler gear that has both a large and small diameter gear as a single piece.
The stud gear drives the large diameter gear and the small diameter gear drives a large diameter screw gear.
I would like to speed up the feed speed but none of the extra gears are big enough in diameter to reach and mesh with the the small gear on the 2 gear idler gear.
Under the nut on the feed screw is first the large diameter screw gear and then an approx. 5/8 th's thick bushing.
If I reverse the bushing and the screw gear on the feed screw, this would allow the screw gear to fit further onto the feed screw and be inline with the big gear on the idler gear.
Then I could by pass the small gear on the idler gear which would allow me to use the extra gears that came with the lathe and will definitely speed up the feed speed.
I am concerned that this will end up with too fast of a feed speed even with the largest diameter screw gear.
The problem is that the extra gears appear to have an interference fit on the feed screw and would need to be driven further onto the feed screw which leads me to believe this is not where they were intended to go.
From photos online it appears these lathes are used with 2 idler gears where as mine came with only one and that may be the problem.
So my hope is that someone can enlighten me on how to use these extra gears to slightly speed up the feed speed or am I missing an idler gear to make this happen?
I am not interested in turning threads at this point.
4. I found a South Bend phone number and called hoping to get some answers.
Turns out they do not offer technical advice and can only sell you parts if you have a part number.
5. Where do I source a hand wheel for the tailstock?
I will appreciate you consideration on helping me understand the use of this lathe and where parts are available.
Herman Pahls
Coquille, Oregon
Herman Pahls
Coquille, Oregon
