doctorgoodwrench
- Apr 9, 2017
Hello all, long time casual reader finally joining in discussion officially... Glad to be here!
I recently picked up a 1975 heavy 10 that was originally put in service as a 3 phase machine. It has at some point along the way been switched over with a 1.5 hp 120 / 240 single phase motor (Dayton 6K272-D)...
The owner had been left to sell it due to the death of a family member, and it was not able to be seen under power. It is wired in, and appears to have been done for some time, but I do not want to make any assumptions as to the correctness of the wiring for obvious reasons.
My concern is the contactor array in the box at the rear of the machine. The control housing attached to the back gear cover is a low speed / high speed / stop button, forward reverse switch furnas unit.
I imagine with a fixed 1725 rpm single phase motor, the high / low function will not be available, but I'd like to use the original controls if possible. I could easily change to a f/r drum switch if I had to, but It looks as though that the machine has been run in this configuration before.... Anyone have experience switching a 3 phase control array over to running a single phase motor that may be able to guide in double checking the current wiring?
Thanks in advance for any guidance you may have for me!
Dan
Dan
