mikbul
Hot Rolled
- Oct 21, 2013
- upstate NY
I always used a four jaw chuck on my 7X16 so I never got anything to check chuck run out. The 7X16 is a 3MT spindle so I used the 3MT test bar to check head stock, tail stock, etc. alignment. I've got a shock I can put in the band saw and cut the ends off and make a test bar to put in the chuck. I'll get back to you
Picked up a piece at the local machine shop today, just have to cut the booger off the end. Charged me $5., wasn't really worth their time. View attachment 89018
“except 4.5MT to 3MT sleeve is off. “ I AM not surprised as it is not easy to make taper to taper sleevs.
Do you have #3 MT in head stock, If so how does that run, should be zero.
Close and three inches out is the range I think fair for a for a low price chuck. Out much past three inches is not a good cutting area so one should consider a center, steady or some way of support.
I agree .0015 is very close for simple three jaw.
Miller test bar.. does it have centers? if so does it check good between centers?
"Just looked up miller test bar = zero run out between centers .0000 ,That is good."
That's the problem, the headstock is 4.5MT and the Miller test bar is 3MT. They give you a sleeve with it to bring it down to 3MT that's where I get the run out with the sleeve, which shows up with the Miller test bar.
I also have a small short ground bar to use in the chuck, maybe 5" or so long, to check chuck run out. The chuck issue I think is my fault, it's wasn't cleaned out good enough so it sticks when you re-chuck the short bar.
The spindle inside run out is not measurable. With the 4.5MT sleeve it's a half a thou. If the sleeve was offset exactly a half a thou from centerline then I should get a half a thou at 12" with the Miller test bar. I don't, I get four so the two tapers in the sleeve are not concentric. talked to him and asked if I should buy one of his or send mine for him to sort out. He said he could sort mine out.
I hope this is making sense?
Mike
The test bar has centers so put it between centers with sleeve pushed on tight. With running the centers dead (not turning)turn test bar to run your indicator on the sleeve and see that it runs good or bad.
*By you first sentence sounds like you did this.. If so how much run out did you find in the sleeve?
Checking with the 5 inch test bar be sure to have most of your chuck jaws filled, so you can probably only have about 3 or 3 1/2 sticking out. Getting .001 is very close.
Buck
I usually just smack it chuck with a rubber no bounce hammer. Loosens it right up.
danny
Notice
