Hi
For some unknown I purchased South Bend 9 lathe, I am largely unfamiliar with this field but would love to make some chips at some time...
It is a 1937 or so and has been in use for much of that so I am sure it has some issues.
It has the QC gearbox and power feed.
It is marked 409AN with a 4' bed
I noted it appeared to be missing some plugs from the cross slide, little holes marked cleverly "OIL" As the little screws were missing I assume that swarf has been collecting in these and washing into the key working parts for years.
I noted about 1/3 turn of play in the lateral slide handle which I assumed was bad.
I then proceeded to crank it through its motion, as the slide approached the far side it jammed, I am unable to return it, the handle slipped, I removed the handle and noted the bolt securing it was not original.
Short story, I would like to disassemble, clean and restore the cross slide, is there a guide for disassembly of this?
I would like to avoid causing further damage.
Harry
Harry
