rcbaughn
- Aug 12, 2015
- Jasper, AL
I am in the process of cleaning up and painting a lathe for the first time in my life for my employer, and I am having a hard time distinguishing where all the correct washers and nuts go since I wasn't the one who disassembled this lathe.
My main question is on the headstock and carriage nuts and washers. The headstock is shown to be bolted to the bed by two thin style jam nuts, but there isn't a second nut actually doing the "jamming", so I was wondering if I could just use grade 8 nut and washers to secure the headstock to the bed? These nuts will go on the threaded shaft that is screwed directly into the bottom of the headstock, and has a 6 point area in the middle where I assume you can make adjustments? Unsure on that as well.
On the carriage, does the bolts that come in from the pan and hold the carriage up use the really thick washers? Or will the thinner smaller ones work and be correct? I am trying to assemble this thing back together the correct way like it was from the factory, but since this machine was rebuilt by the Navy once before, and I am not the one who took it apart this time, I suspect that some hardware was put in the wrong place. I am actually missing two jam nuts that are suppose to hold the headstock to the bed, but I see no reason grade 8 wouldn't work in their place if someone can okay that.
Maybe I am being too OCD about washers and nuts and the like, but I don't want to get to the very end and be missing a bunch of hardware or have hardware in the complete wrong spot and have to disassemble. Thanks so much and I can't wait till this thing is running and I am done with it!
