Paint: That brown coler
Rex TX
Titanium
Sep 20, 2004
Fort Worth, Texas
Paint: That brown color
I picked up a couple of SBs a few weeks ago. One is a 10L which appears to be manufactured 1951. The color is that matte brown. Not crazy about that, but I don't think I want to do a full restore and color change as i don't intend to keep it. Is there an off-the-shelf match for this paint, or at least a mix formula that I can take to a local paint shop?
This one is for sale. I'll post it in the classifieds shortly
Brown? It doesn't look like brown to me. It looks like ordinary South Bend gray. A number of members who have re-finished their Heavy 10's have made recommendations on how to mix the paint that they used. The usual source was machinery enamel from Tractor Supply. I painted a 10L about 5 years ago. I bought my paint from Tractor Supply. They sold Valspar, and have switched brands since then. My paint was a mixture of one quart of Valspar Ford Gray and one pint of Valspar gloss white, and that was satisfactory to me. Applied smoothly with a brush, and is standing up for durability. Check with Brad Jacobs, his paint source was Sherwin Williams.
Brown? It doesn't look like brown to me. It looks like ordinary South Bend gray. A number of members who have re-finished their Heavy 10's have made recommendations on how to mix the paint that they used. The usual source was machinery enamel from Tractor Supply. Check with Brad Jacobs, his paint source was Sherwin Williams.
He has the mix posted, and it is a nearly perfect damn match...
Scott
Oh it's definitely brown. I have seen a few others in that color.
I have a gray 10K sitting beside it now, and I've owned a few others, all gray. The shade varies, but not THAT much.
if it's for sale why paint it?
guys that buy these thing typical want to do it theirself, and an extra coat of paint is a turn off to them.
If it doesn't sell quickly I know I won't be able to keep my hands off it. Most of it's good enough with just a good cleaning,l but a few areas would benefit from a freshening. At the least I'd like to touch up some bare areas on the headstock. Worst case I'll include the paint with the lathe if it sells.
For you non-believers out there, here are a couple of pics of the brown finish next to some SB 10K parts with original gray paint, from 2 different lathes.
I cleaned some of the 10L parts and there is no gray layer under it. There is a bright green layer which I think is primer.
BTW, can anyone tell me about that compound in the 2nd photo? It's 9"/10K, but I haven't seen one with 2 threaded holes instead of a T-slot.
Personally, I'd rather buy the paint myself. I wouldn't trust the color matching by someone who can't tell the difference between brown and gray.
Rex,
If you wait long enough, they will turn to black in a dirty enough shop...LOL
I think it's just sun fade and dirt that turned it that color. How about inside the covers where it isn't exposed to the surrounding environment. Is that the brownish color also ?
Maybe Ted will chime in and say if SB ever painted lathes brown, but my guess is fade/discoloration.
Rex,
Inside the drawers? Same color. Pretty uniform all over
same color as a Weimaraner dog, oddly enough
I have refurbed dozens of lathes, mills, shapers including 5 or 6 South Bends. I always try to find the OE color early in the process. 97% sure this is the original paint. Maybe a special order? May have to buy the build card
Maybe not so odd. I kind of vaguely remember that some machines during the war era were painted a different color, but my memory is only good for a few weeks anymore... ;)
And I know you have, so with that said, I am willing to take your word for it. As I mentioned, maybe Ted can comment if/when he sees this thread. I think he's the one that would know for sure.
In one picture you can see both lathes together in contrast and clearly see one is brown and one is grey. Whether or not it's factory I have zero idea, nor do I care, but that lathe is definitely painted brown.
Yes, you're correct, the 2nd pic in the 1st post. It shows the color contrast as does the 3rd pic show the brown...
However, be careful, there's a difference between the light blue and the grey they used on the older machines. I have a '46 9A that is grey. And it's a darkish grey, more so than light grey.
OK, I ordered and received a Serial Card from Grizzly.
Took two tries, since the first round they just slapped it on the platen crooked and hit Scan, the it cut off one long corner. They rescanned it but I'm still not impressed with the care they take.
Anyway, I was hoping for some insight on the color. I'm not seeing any reference to that on the card, front or back. The lower half of the back is blurred, so that I can't tell what data it contains. Maybe someone else has a serial card scan that is clear and can tell me what those fields are?
FWIW- I am reasonably sure it's a repaint because it appears to a war era machine but has a later style tailstock.
April 1951 - it would have to be the Korean, er...Police Action
If it's a repaint, it's a very thorough one. I have seen no sign of any color other than the bright green primer. I have had several assemblies apart for cleaning, and removed the paint from the compound accidentally, it came off in sheets. Brown sheets only. Not a spec of gray paint anywhere on the machine or cabinet - except the inside of the drawers.
I did state the inside of the drawers were brown, but I looked again today and they are gray inside, so there is that. I'm still of the opinion that this was a custom color at buyer's request.
Where's Ted?
