Play (longitudinal) in lead screw
Results 1 to 7 of 7
    Aug 2008
    Queensbury, NY
    227
    8
    Default Play (longitudinal) in lead screw
    I have a double tumbler 9a, with an apparently loose lead screw. When the screw is disengaged, I can grab it and move it left to right--quite a bit of slop. Before I take the gear box & screw off, Is there anything I should look out for? I'm assuming (hoping) it's just a loose nut in there somewhere. I can't find a diagram that shows the lead screw inside the box.
    Oct 2012
    central Pa., U.S.A.
    248
    123
    43
    Perhaps you could peek under the quick change box with a mirror and flashlight. While I have never worked on a 9"
    gearbox, I assume (perhaps erroneously) the design is similar to the heavy 10,13",14.5", and 16". Inside the gearbox, mounted on the leadscrew is a bearing, a hubbed gear (which puts the teeth on the gear in mesh with the
    second gear on the gear "cone". This hubbed gear is retained on the leadscrew with a washer and nut. I have seen
    double nuts, and a single lock nut, on different gear boxes. It's been a few years since I had one apart, but if the retaining nut comes loose, or off, the leadscrew can float between the outside edge of the gearbox, and the leadscrew support bearing on the tailstock end of the bed Hope this helps. PB
    Sep 2010
    moscow,ohio
    4,215
    423
    1198
    No bearing on the 9s...it's pretty common for them to develop some slop.
    How much slop are we talking??
    Aug 2008
    Queensbury, NY
    227
    8
    It's about 1/8"
    Sep 2010
    moscow,ohio
    4,215
    423
    1198
    Ya, that's a lot.
    IIRC it was about .004" from the factory.
    I would say time to pop the gearbox off, or even just flip the whole lathe over and have a look see.
    Jun 2012
    Michigan
    7,832
    2272
    2535
    Aug 2008
    Queensbury, NY
    227
    8
    Thanks for that.
