Greetings all,
I am new to this forum and hope your knowledge will help me in my next lathe project. I recently aquired a somewhat damaged southbend 16 lathe that fell from the bed of a truck. It sustained serious damage to the base and casing of the gearbox. It has no motor, has a broken wheel on the carriage, and has mild surface rust on most of the unprotected parts(especially the undercarriage drive pulley). The rest of the machine still looks to be in fair shape at first inspection. The gears and pulleys seem to spin freely and do not have excessive wear. The ways are OK (.003>) with my 18" straightedge. And the carriage moves smoothly with no slop when turned with a pair of visegrips.
I am interested in trying to repair this machine but do not want to waste my time and money on something that will end up costing more than it is worth. The base is my first concern. Iv'e looked at many pictures of southbend 16 lathes and have only seen one remotely like my base. It had been welded down to the floor of a submarine and all the feet were cut off -none too evenly! I think it is cast steel(not iron) judging by a spark test so I think I will try to weld it. It also loks like it was modified on the tailstock end which is made of 1/4" anlge iron and a 3/8" plate. Since I have no motor and the lags are all shortened I do not know how high I should make the base. Should I just scrap the old base and make a new one? (Really not on my want to do list since I may find hidden damage later.)
Also, this lathe sat for several years with the two 5/8" standoffs that support the tailstock end of the bed removed- thus the carriage and tailstock weight were added to that end and I don't know if that could have been enough to warp the bed.
Any rebuild advice or sources for "16" parts (not much on Ebay) would be appreciated.
Bigpagoda
Bigpagoda
