I have a SBL heavy 10L (1976) and want to put an adjustable speed motor system into it.
Have some questions about VFD or DC motor with adjustable speed and reversing.
1. What is the average cost to set up a VFD system if you have the 3-phase motor?
2. Would the VFD have a full range speeds and be totally reversible?
3. Is the VFD as quiet as DC motor at all speeds?
4. Why do most people choose VFD over DC?
5. If given a choice with no cost differents, which would you, choose VFD or DC and why?
Thanks Chet
1-I have installed a VFD on my 1 hp motor of my Millrite milling machine and the cost for doing it including the VFD unit (TECO), elec cable, and all the other electrical items that I needed cost a bit less than $250.00. In my case I had to run wire from 220 V cable to the other side of my shop and buy new 220v receps and so forth. I paid about $150. for the TECO.
2-Yes it will have a full range of speeds, but running a very low motor rpm while making heavy cuts will require changes to the belt/pulleys. I decided not to add VFD to my 3-phase 10L and bought a new single phase rubber base mounted motor that cost a bit more than $200. I did this because of personal preference not technical.
Although the late 10L's can run at 1400 rpm or so spindle speed, because of balance issues through out the drive train and headstock, 1000 rpm is about where you will end up maxing your speed. For example a loose bull gear to headstock cone pulley connection via the bull gear pin will cause issues at high speed. I know this because I cured some of my vibration issues by making a new larger bull gear pin and drilling a new hole for using it in the headstock cone pulley. I also made a new underdrive shaft, installed new bearings of same and trued the 10inch diameter two step drive pulley of the underdrive---all of which reduced vibration at high speeds. When I run at very high headstock spindle speeds, I usuall use a collet in lieu of a 3-jaw or 4-jaw chuck in order to reduce vibration. Vibration to me is anything I can feed by placing my hand on the headstock cover while the lathe is running.
3-No, the VFD will not be as quite as a DC motor at all speeds, but it will not be harsh to the ears. There is some motor noise that is generated by the VFD, but it can be reduced by the VFD program changes. I have a DC motor driving my 10L carriage feed screw and it is very quite. I reduced nearly all the noise form my Millrite motor by the VFD program.
4- Usually cost/benefit issues
5- In your case (10L and assuming an underdrive cabinet model as were produced in 1976) the selection would be which will run the most quite as the cabinet will amplify any noises from the motor and drive train. Both DC and AC motors can be mounted in rubber so the issue is likely moot.
Regards;
Steve
