IronReb,
It pains me to have to admit this but I am honestly do not know how the RPM and feed rate factors into lathe operation. On a mill it is no problem for me just two equations and I know exactly what rpm to spin my tool bit and what feed rate to set my machine to make sure I am not snapping bits left and right. I have looked but maybe I missed something somewhere. Again guys relatively new on the lathe so take it easy on me.
No shame in not knowing bro.
The fact your were able to turn a pin with no knowledge at all of an engine lathe operation says a lot.
I am not the best teacher online, hard for me to convert what I know and feel into text sometimes so here goes...
Tooling
It makes not much difference at all what tool you decide to use. HSS blanks are great for forming a feature, radius or grooves.
They also can do turning just fine but at much slower RPM than carbide.
The trick to it though is proper grinding and tool holding.
Brazed on carbide is a great next step up
https://www.mscdirect.com/browse/tn...Holders/Single-Point-Tool-Bits?navid=12105896
These tools will machine right out of the box.
They can be re-sharpened but it takes a special grinding rock and is a bit more of a pain to grind, not much but
for sure more messy because the rock breaks down so fast.
Inserted tooling for one who uses a lathe often is the way to go, depending on the style of insert, you can get 6 cutting tips per insert..$3-$18+ each.
Dull the tip, rotate insert and a minute later your machining again.
All tooling have parameters they operate best at in a given material.
And also very important, tool nose center.
Its important that no matter the tool that it is on the center line of the part, to low or high will cause issues like broken tool edges
and crappy finish.
Boring on the other hand seems to work better if it is just slightly higher than centerline.
A quick easy way to check is to eyeball the tool tip to center of the tip of your live center which is on centerline of the machine, or should be.
RPM
Tooling is rated at surface footage. The numbers I use next are just for examples only and are not correct math or from the book....
HSS machining mild steel is something like 60-90 surface feet a minute (SFM), meaning if you were to drag that tool along a straight line it can handle
the heat generated if it traveled 60-90 feet in one minute.
If you were to drag it 180 feet in one minute you would generate to much heat and melt your tool tip.
If you dragged the same tool 20 feet in a minute the material will tear and stick to your tool tip and leave a crap finish.
Its the same game with even a high dollar inserts except instead of running at 60-90 SFM like the HSS, the carbide insert will need to run at say 800 SFM.
Meaning your lathe would need to be max RPM for smaller diameters.
There are tons of apps to convert SFM to RPM, or you could use the pie X diameter stuff...or is it pie times radius? Hell, I forget now.
Feed
1/32 tool nose radius
.006-.007 and a little sand paper = seal fit.
.008-.010 = nice finish with slight tool marks.
1/64 radius...about half
Hope this helps till one that better at explaining chimes in.
