xplodee
Hot Rolled
- Oct 14, 2013
- Allentown, PA
Hi All-
I'll be rebuilding my 10L soon (working my way through painting currently). This is a total restoration, everything is being re-ground and scraped in, etc etc. I'd like to fix any cast iron bearing wear in places like the gearbox and apron.
Could some speak to what the ideal clearances are between journal and replacement bearing? I assume 0.001" would be sufficient for items like the gearbox axles and cross slide crank journal. Am I way off base?
Also- what's a good interference for the brass/cast-iron press fit? Do you guys press fit then final bore the brass to size after the press fit? Or do you precision machine the ID and OD for the brass on a lathe and use loctite 660 or equivalent for installation of the bearing into the cast iron?
Thanks for your advice, it's appreciated.
