Removing tags
Results 1 to 4 of 4
Thread: Removing tags
    Jun 2006
    Sault Sault Ste. michigan
    103
    Default Removing tags
    I am having trouble removing the small pins that hold the tags on the machine, I don't want to damage the tag? where do you get replacement pins
    Thanks Carmine
    Jun 2003
    North Carolina
    337
    8
    Default Drive Screws
    The pins holding all the tags are typically drive screws. You can get most sizes at McMaster Carr though you have to buy a box. If the drive screw is in a blind hole that can not be accessed from the rear, the best way to remove is to hole-punch a piece of electrical tape about the size of the head and place it over the drive screw to protect the plate. Take a dremel tool with a cut-off blade and grind a slot in the head so that it looks like a round head machine screw. Tap it a few time from the side with a pin punch to loosen it and then turn it counterclockwise just like you're unscrewing it. They are pretty hard steel and sometimes they break off so if that happens remove the other screws and remove the plate. There may be enough left sticking up to grab with a small pair of vise grips but if not, just drill it out carefully with a carbide drill bit. Regards, Steve
    Mar 2011
    Maine
    63
    I can see mine from the rear,
    can i drill them out from the rear?
    or do i chance the drill bit slipping to the side, all i have is a hand held drill ,,grrrr,,,
    Quote Originally Posted by SWBrooks View Post
    Jul 2010
    Virginia, USA
    3,199
    76
    521
    They are hardened, don't try to drill. If you can see the back, drive them out with a punch.
    allan
