Fuzzy
- May 15, 2006
- Cleveland, TN
While trying to clean up the guts of the apron on my SB 9A, I managed to break off the screw that holds the clutch knob on the shaft. I tried heat, Kroil, GENTLY working it in both directions... finally it snapped off, leaving the stud in the shaft. I may be able to get the broken piece out of the shaft & salvage it (the shaft), but I will need the special screw that was damaged. Any of you folks know where I might obtain either or both of these pieces?
Also, anybody know what the thread size is on this screw ??
Thanx
<<<__ Bøb __>>>
Thanx
<<<__ Bøb __>>>
