hello.back after a hiatus of being a single parent whilst 'she-who-must-be-obeyed' was in the motherland.
I have been reading posts on the flat belt on the SB.
Here are the steps i use to run the lathe.
Belt is slack.
Put belt on pulleys to be used
Turn on motor
Push camlever over(tighten belt)
Take cuts.
Pull lever back(slack off belt)
Turn off motor
Measure work.
Repeat.
When i stop for the day I loosen the belt.
Is this right?
I read an article where a bloke had converted to a serpentine belt and commented that he could not use the cam lever and adjusted tension with the turnbuckle, so i assume he left the belt under tension all the time.
How tight should the belt be? How deep a cut on aluminium or steel before slipping is 'normal' for an SB9? That I think is the only way to see if the belt is tight enough. I am scared stiff of ruining the machine!
I have a leather belt, but am thinking of the serpentine route.
Cheers
Ant
Belt is slack.
Turn on motor
Take cuts.
Turn off motor
Measure work.
Repeat.
Is this right?
Cheers
Ant
