Hello: Have been given lots of help and encouragement in this matter. Problem as follows
(it was there when I bought it )
trouble. Lead screw will not turn when under load. ie cutting threads or using clutch.
removing QC box discovered the gear which meshes with the lead-screw gear.(the last gear) will slip on the shaft. I need some where to get a
dissembly proceedure. undoubtedly there is a key
missing. but no keyway slot visible on that end of the shaft. No set screw no no nuthing. scraping away paint from outside box however still uncertan on how to get the thing apart ..with some grace.. have photos which show the gear etc.....there are no broken gears
..I have removed the pin holding the splined gear
so I could slide it away from troublesom spot
for observation. the troublesome gear has a small
notch which is about .125 deep..
anything fellows? [email protected]
