SB 13 cutting 12tpi with tumblers set for 16tpi
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    May 2016
    Tennessee
    24
    Default SB 13 cutting 12tpi with tumblers set for 16tpi
    I have a 70's vintage SB 13, just learning to run it. Today I attempted to cut a 16 tpi on a piece of 3/4" cold rolled bar stock. The thread looks good, but it cut 12tpi.
    It has a double tumbler gearbox, & on the plate on it calls for the left tumbler to be in "b", with the right tumbler to be in the first (far left) position. I tried running on the bull great but the threads were really fine.
    Any help greatly appreciated.
    I also posted this in "gunsmithing"
    Aug 2013
    775
    458
    212
    Check your gear train under the left hand hinged cover. Maybe some gears switched around. I believe your chart calls out two different gear tooth counts for the A tumbler...
    John
    Jul 2004
    Houston, TX USA
    27,464
    Good thread here - also addresses the need for correct use of the several levers on the apron
    13" SB gearing issue
    The most important aspect is that the 24 and 48 tooth gears are ONLY for the STUD position (but not at the same time) , and the 64T is ONLY for the input to QC box position
  4. Likes MetalCarnage liked this post
    May 2016
    Tennessee
    24
    It does, 48 & 24 on the stud gear, have to figure out which is stud gear. Another gentleman replied with a link to a 13 with similar problem, going to take the iPad to the garage and try to figure it out. I looked at the thread and know that I have a 64 tooth on the tumbler input shaft that is being driven.
    I'll post what I figure out.......or more questions.
    Jun 2012
    CANADA
    British Columbia
    388
    53
    76
    If the the 64 tooth gearbox input gear was replaced with the 48 tooth gear it could be the problem.
    May 2016
    Tennessee
    24
    I think the 64tooth on the gearbox is right, looking at the thread johnoder posted. I took pictures, if i can figure out how to post them.20170616_195026.jpg
    May 2016
    Tennessee
    24
  9. #8
    May 2016
    Tennessee
    24
    Thanks for the link Johnoder, good read, going to clean up my gears and count teeth over the next few days, have to work tomorrow,
    Many thanks, I'll get back to it in a day or two.
  10. #9
    Jul 2004
    Houston, TX USA
    27,464
    Looks like the 127 / 100 metric transposing idler
    I marked your photo for you. Probably is not 24 or 48 teeth
    ON EDIT:
    Here is the double tumbler HTRAL if needed. Probably more legible to acquire a paper version
    http://campkahler.com/files/How_to_R...he_SB_1of2.pdf
    http://campkahler.com/files/How_to_R...he_SB_2of2.pdf
  11. #10
    Jun 2012
    CANADA
    British Columbia
    388
    53
    76
    Do you have other gears from the transposition set or the original set?
  12. #11
    Sep 2010
    moscow,ohio
    4,757
    459
    1433
    You just need to replace that 34?? tooth gear with your 24 tooth gear.
    You are fortunate as you have the compounded 127/100 metric gears in the idler position...no need to change that, the compounded idler only come into play when you are using the smaller outer 100t outer gear to drive the gearbox.
    BTW- contact Ted about your carriage lock, he may also have the gearing instruction sheet for utilizing the metric capability you have.
    [email protected]
  13. #12
    Jul 2004
    Houston, TX USA
    27,464
    Scan thanks to Mr. Wells
    If you had one of these charts you could actually read, you could discern all the various stud gear tooth counts that are involved in cutting metric threads
  14. #13
    Sep 2010
    moscow,ohio
    4,757
    459
    1433
    to be clear for your purpose you need the 24T stud on the reverser assembly...see Mr Oders post #9
  15. #14
    May 2016
    Tennessee
    24
    Thanks, I'm pretty sure i have that plate on the gear cover. I counted the teeth on the stud gear that's in use, it has 32 teeth
    I counted the teeth on the other stud gear, don't remember off the top of my head, but I know it wasn't 48 tooth.
    I don't think that i have a 24t gear, looked on ebay this morning, there is one listed, but the lister says it is for a single tumbler machine & wont work on a double tumbler.
    I need to read a lot about this lathe to figure it out, what configuration it is etc.
    Ken, i have no other gears other than what is on the machine.
    I need to clean all of the old grease & gunk off of the gears & count the teeth,
    Anyone have a 24t stud gear that will work on s double tumbler machine?
  16. #15
    Sep 2010
    moscow,ohio
    4,757
    459
    1433
    comfirm but I believe this will work...
    24 TOOTH CHANGE GEAR FOR METAL LATHE MACHINE | eBay
  17. #16
    Jul 2008
    South Bend, In
    2,470
    125
    198
    FYI:
    The standard change gears for the 13" are 14 DP. The Metric transposing gears are 16 DP.
    Ted
  18. #17
    May 2016
    Tennessee
    24
    Hi Ted,
    I'm new to machining, learning as I go. So google is my friend, I looked what DP is and it appears that just changing my stud gear wont work, I'll look up hot to measure dp.
    Im at work right now, wont get home till 5.
    Iwananew10, I'm watching it on ebsy, if it will fit my reversing lever & is a part of the puzzle ill get it.
    I need to read up on this, research dp & how to determine if I need a complete set of gears. If I need a complete set, id rather buy them as a set than piecing the puzzle together with individual gears
    Really appreciate the help from everyone.
  19. #18
    Mar 2016
    New Jersey
    921
    16
    179
    DP = tooth count + 2 / outside diameter of the gear.
  20. #19
    May 2016
    Tennessee
    24
    Thanks Gadget, I'll check them this evening
  21. #20
    Jul 2004
    Houston, TX USA
    27,464
    Which says the stud gear installed, reported to be 32 teeth, is 16 DP - since it is engaged with the transposing set
    Which also means that the usual every day (not part of metric rig) stud gear, stated to be 14DP, is not going to be able to use the metric transposing set as an idler
