New guy here. I'm working on a 1980 vintage 13" x 5'bed, Cat no. CL0145C, S/N 17048T, Hard bed, D1 spindle, Taper attachment.
The Saddle cross feed Thrust bearings are:
pn AS841H2 (measured id .630, od 1.120, 10 balls, .155 diameter)
pn AS841T2 (measured id .630, od 0.988, 10 balls, .125 diameter)
The cam operated clutch thrust bearings are similar:
pn ASA4629TH1 (measured id .630, od 1.120, 10 balls, .155 diameter)
SBLatheman Ted has the H2 bearings, but not the T2. Does anyone have a source for these? These T2 seem to have been used on the 13" cross feed only and the 13" and 14 1/2" clutch.
I bought this lathe several years ago but have just begun work on it. It is a nice machine, probably from a school, more abused than used- the usual chewed up compound from hitting the chuck, but all gears,bearings, and feed screws look good.
The saddle crossfeed bearing at the dial end (Form 911-J,Item 15)is missing balls and the other bearing (item 17)was replaced with a bushing.
The clutch bearings on this lathe are good and were used to get the dimensions, I list these for future reference.
Thanks in advance,
Bert
Thanks in advance,
Bert
