Hi and thanks for the great forum full of lots of excellent info.
I just joined and will be looking around for a while. I found this site while looking for info regarding my new to me SBL. It's a 1943 or so (it's at work at the moment so I can't take pics or remember the serial). It has the cast iron bell bottom with under drive and a 3' bed (not hard). It appears to be one that was set up as a turret lathe with a coolant tank as there is a "drain" hole in the chip pan near the base on the right side. It didn't come with the turret but did come with a tailstock without provisions for bed wipers and a really nice telescopic taper attachment. The compound is in really nice shape with no signs of crashing. If I remember, it has 1001Z as the catalog number.
I already got a felt kit and the "how to" book so my plan is to tear down, clean, repair what is needed, repaint, and use it at home. I will be making a new cross feed screw at work on my Monarch CK12 to fit my new nut as there is lots of wear in it.
One thing that I wonder about is the spindle bearings. I have the removable bearing caps but it doesn't look like there are expander screws on top. Does this mean I have plain bearings? If so, do I need to do anything special to remove the caps?
I will provide pics when I can, but it is all in pieces now :-(
