Hello all: Without boring you all on my background, I have a Southbend Heavy 10 Lathe Model CL187A. Sadly, the previous owner used this for woodworking, so six months later I'm still cleaning sawdust out of it.
My first "real" project was making a stop nut for my old Craftsman 150 drill press. I couldn't find one, and it is a 5/8" nut with 12 TPI acme threads. I tried at first with steel, and real fast smartened up and went to aluminum. I'm done, and happy with it.. but some questions.
For internal threading on a relatively small diameter part, how do you keep the cuttings out of the threads you just cut? I'm using collets, and all the spiral cuttings are left in the part I am making. I ended up drilling it all the way thru, but then the shavings just end up at the end of the part inside the collet. And it seems like they want to grab the boring bar and damage my cuts.
Next question... 12 TPI has the feed going fast in my opinion. I'm going as slow as I can, but it is still fast and timing has to be right or the slide will crash into the headstock. But they didn't have VFD's 50 years ago?
I might put a VFD on this. Can someone save me from trying to measure the motor plate advise me what mount these use for the motor? It's a 1800 RPM 3/4 HP single phase motor manufactured 30 miles from where I grew up. (Schenectady NY) My lathe is a CL187A, which I guess is a "10 Heavy". If you dropped it on your toe you'd think it was heavy for sure.
Thank you in advance for your patience and help.
Oh yea... now I know why the military pays 3,000 bucks for a toilet seat. Even at minimum wage this nut would have cost a lot of money!!!
Wayne
Wayne
