My first question as a newbie:
I live in Sweden and have a SB 9C which I think was made in 1939.
It seems that South Bend exported lathes to Sweden:
http://www.wswells.com/serial_number.html
(See serial # 98786)
...and it also seems that there were "metric" 9" models:
http://www.practicalmachinist.com/vb...ghlight=metric
Yesterday I tried to measure the pitch of the cross feed and compound feed screws. It seems that for both, the movement would be 5.00 mm for two full turns of the feed screws.
However, the measurements were not very accuate and it seems likely that with inch pitch feed screws (maybe 10 TPI?) the movement would be 5.08 mm so the difference is not very significant.
The collars are graduated 0.2 0.4 0.6 up to 2.5 for a full turn. Guessing again I would think that a collar graduated for a 10 TPI feed screw would instead maybe be graduated 10 20 30 up to 100/1000 (0.1) inch for a full turn (?)
Does anyone know for sure if there were any SB 9s with metric feed screws?
