Results 1 to 6 of 6
    metalmagpie is offline Hot Rolled
    May 2006
    Seattle
    828
    Default SB compound question
    Some of you may have seen this question posted elsewhere. I was told the experts are over here, hence:
    I'm working on retrofitting a South Bend milling attachment to a lathe of European design. It seems that South Bend aprons have two set screws (usually they stick out with square heads) each 45 degrees off axis from the crossfeed screw axis. Those screws push on beveled pins which bear on a male circular dovetail on the bottom of the compound rest. Or milling attachment, or whatever else is mounted directly on the apron.
    My question is about the beveled pins themselves. Did South Bend thread the holes they move in all the way and have the pins be slightly smaller than the minor diameter of the threads? Or is the part where the pins slide bored to a smaller diameter than the part where the set screw threads? Or what?
    This particularly applies to a 14" South Bend lathe but I'm guessing they made them all conceptually the same but just sized differently. In fact, I would greatly appreciate the actual dimensions of the pins and screws on a 14" South Bend, thanks!
    metalmagpie
    jkopel is offline Hot Rolled
    Apr 2010
    Seattle, Wa USA
    530
    On my 9" lathe the pins are larger then the minor diam. and move in a bored out hole.
    May 2006
    Seattle
    828
    Coupla corrections: it isn't the apron I'm interested in, it's the cross-slide (saddle?). Also, SB calls the pins "shoes". Really need dimensions if you have a 14-1/2" South Bend lathe.
    thanks, metalmagpie
    kitno455 is offline Stainless
    Jul 2010
    Virginia, USA
    1,412
    I don't understand why it matters. It is not as if the cone knows the difference between a 1/4 and a 5/16 shoe. As long as it is soft, has the right angle on the end, and travels closely in its bore, any shoe will do.
    allan
    May 2006
    Seattle
    828
    I want to clarify what I need. I need dimensions for parts no. 42 and 43 from this drawing: http://tinyurl.com/9ksvtm6 sized for a 14-1/2" lathe.
    Thanks!
    metalmagpie
    OldMachinist's Avatar
    OldMachinist is offline Cast Iron
    Mar 2010
    Nashville, IL USA
    322
    I have a 14 1/2" cross slide with shoes and screws sitting on the bench right now. The shoes are .484" in diameter and 1 3/8" long. The working surface is a 1 1/4" radius cut at a 30 degree angle. The set screws are 9/16"-12 x 1". The holes in the slide are .485 thru and tapped about 1 1/4" deep.
