I am still trying to figureout why my rear bearing sucks the oil out of the cavity almost immediately.
I am using a needle roller thrust bearing between the casting and the take up collar. Since the thrust bearing race presses against the casting and has an id that matches the spindle I think the rece is siphoning the oil out of the oil cavity.
The inside of the take up collar is beveled so that the perhaps the oil will flow back into the return holes rather than siphoning out.
In the South bend parts diagram shown below, what are the parts 47 and 30, pin and take-up washer? My lathe did not have these parts, that is the reason I have the thrust bearing.
John
John
