bama7
- Jan 7, 2014
- Middleburg, Florida
I am having a very difficult time getting my powerfeed lever to move out of neutral position. I have cleaned and inspected it and still cannot get it to function as it should. The halfnut lever is disengaged. I even try to move the halfnut lever slightly while moving the powerfeed lever to find the "sweet spot" where the locking pin goes in place, but no luck so far. I AM NOT SAYING I WOULD DO THIS FOR A PERMANENT FIX,but I would like opinions, especially if you really know what happens if you do what I am asking about. If you remove the pin that keeps you from engaging the halfnut lever and the crossfeed lever at the same time what could or would happen? I know it has got to be there for a very good reason, but I am curious. I am going to remove my pin to make sure my lever and crossfeed will work as it should and then wait for my replacement parts to get here. Thanks for any help and or thoughts.
