Evan
Titanium
- Jan 29, 2004
- Williams Lake, BC, Canada
I thought I'd show the milling attachment I made last year for my SB9.
It was not difficult to make and cost less than $50 cdn for parts and materials.
I used the top slide for the vertical axis. It has a X,Y range of 2.25x 4.5".
It can be set up in about two or three minutes.
It works well, far more rigid than the available ones on the market. It is all aluminum, very thick sections. I use the existing bolt holes in the cross slide to attach it.
The attachment is aligned by the use of two setscrews in the ears that bear on the back end of the cross slide.
I can take a profile cut of 1/8" X 1/4" in steel with a 3/4" end mill without problems.
