I am rebuilding my 9A and found two parts missing from the apron. The oil drain plug!!!! This is also called a pipe plug - PT1511. Also missing is the handwheel pinion snap ring or spring - PT409NK1. I am hoping these are fairly standard sizes. Does anyone know the relevant dimensions so I can find and purchase the plug and the ring?
John
Plug sizes are far enough apart, plus cheap enough, just buy 2 or 3 that look 'close', see which fits.
Snap rings plain, internal, external, "E", "C" shapes
etc are also so cheap it is easier to buy boxed collections of each type, do the same, rather than waste time or fuel chasing one at a time.
Same again for cotter-pins, 'O' rings, taper-pins, roll pins, Allen-head fasteners, machine-screws in general (buy long, learn to cut shorter ..) and set-screws.
Just build a small stock, let it 'pay you back' in saved time not having to constantly go-chase.
Everything I just mentioned could probably fit into a single 'shoe box'.
Half full. Unless.. you go for the BIG collections so as to also take care of the motorcars and OTHER machine-tools. Then a rolly-cabinet of their own.
Bill
