ebenbildmicroscopes
- Jul 19, 2004
- burlington, north carolina, usa
Several years ago, I purchased a 1967 (according to the serial number) Southbend 13" with double tumbler gearbox. It was apparently made just prior to when the beds were all flame hardened for the thirteens - which has always been a little bit of a let down, but "down south" these machines are not so easily acquired! At any rate, I'm assuming the thing must have been used in a school because the top of the compound has been beat to death with chuck crashes. The machine seems otherwise fairly normal - ie backlash where you would anticipate - the sleeve bearings in the head are beautiful - I think I'm the first one to ever tear into them.
I've heard that "spray welding" is the way to go to build this compound back up: #1 - anyone got advice regarding reputable welder, #2 - anyone had problems with warping or distortion in connection with the heat of the welding process..............educate me where to start and any lessons learned!
THANKS, in advance, for any assistance............I gotta get this machine fixed up pretty and running!
