Set-Tur Chucks
Results 1 to 4 of 4
Thread: Set-Tur Chucks
    Jan 2010
    Bismarck, ND
    139
    13
    Default Set-Tur Chucks
    I am looking at adding a 3 jaw 6" Set-tru chuck for my lathe. I am not exactly sure how it adjusts concentricity and I am wondering if it is a good addition for more presise work holding than my existing 3 jaw chuck. What kind of accuracy can I expect and what are the better brands to look for? Thanks
    Regards
    Skipd1
    Aug 2004
    Richmond,VA,USA
    1,961
    146
    664
    Set Tru chucks are nice and I do own a couple of them. I will add that if you are looking for accuracy you should be using an independent four jaw chuck however. You can dial in your part to whatever accuracy you need in a minute. I would never rely on any three jaw for real accuracy. Collets are nice but it takes more time to set them up then it does to just dial in your part with a four jaw. I rarely use the Set Tru anymore.
    Feb 2009
    Wisconsin (from May to November); Florida (from November to May)
    1,607
    43
    386
    Quote Originally Posted by skipd1 View Post
    Regards
    Skipd1
    There are four set screws around the perimeter of the chuck that allow you to dial in a round workpiece, like a four-jaw chuck. If I were you, I would purchase the 6 jaw version of this chuck, rather than the 3 jaw version. I have a 6 jaw Adjust-Tru chuck, and it is very convenient for accurately turning round workpieces. Once you get the first workpiece dialed in, you can expect repeatability within a thousandth.
    Lord Byron
    Jul 2004
    Houston, TX USA
    27,351
    Here is one I made - works good:
    Shop Built "Adjust True"
