Which size Aloris for SB 16?
Results 1 to 7 of 7
    Apr 2006
    Laytonsville, Maryland
    535
    11
    Default Which size Aloris for SB 16?
    The Aloris catalog lists EITHER BXA or CXA for a 16 inch SB. Mine is a late model with hardened ways and lever clutch.
    The BXA is less expensive,the CXA is likely more rigid. I am concerned about whether or not one of them is at/near the limit of its vertical height adjustment range for setting proper tool point height.
    Anybody have experience with either? Comments/problems/likes?
    Thanks in advance.
    Nov 2015
    595
    25
    224
    I have a CXA on the SB16 I use at work. None of the tool holders are at their travel limits.
    Apr 2015
    Ohio
    9
    Either one will work, however I would go with a CXA size just because there is more to it. Height adjustment should not be a problem if your using 1/2" or 5/8" shank insert holders. You can also put a "shim" under the insert holder to raise it up if needed. When I worked in a R&D shop I had a 13" lathe with a CXA toolpost and had no real problems with it.
    Oct 2012
    central Pa., U.S.A.
    272
    123
    51
    CXA works for me. If you had a 13" and a 16", and could only buy one Aloris...then I'd say get the BXA. The CXA is sized perfect
    for the 16". pb
    Jul 2013
    Chicago
    180
    16
    52
    I also use a CXA in my 16's. I have a spare BXA leftover from when we had a smaller machine, and when I tried it in the 16 it was just too short. Most of my insert holders have a 3/4 shank.
    Marc
    Mar 2012
    Geilenkirchen, Germany
    1,894
    1151
    940
    Yes, either will work, but I would use a BXA, as it is plenty stiff enough. I use a Multi-fix B on my 18" L&S with no ill effects. I do have to use a spacer under the head. One unmentioned advantage, beside price, of using the smaller size is potential interference with the "C" size.
    Jan 2017
    Indiana
    16
    38
    Adding to this thread just to provide another data point.
    I recently purchased a BXA sized Bostar QCTH (CDCO/ebay) for use on my SB16. I had to add shims (~1/4") under the QCTH to bring the tools up to center. BTW, I typically use 1/2" shank tools. I'm not real pleased with the setup, but it should be fine. Honestly though, if the quality of the QCTH was a bit better then I might be quite pleased with the setup.
