Perhaps a combination of D1-4 adapter to threaded spindle plus the same collet chuck as mine would be an option although, I admit, not ideal.
"Bolting" it to a backplate...
Sounds very time consuming. Wouldn't one have to indicate the hole pattern, then transfer that precisely to a backplate? Don't have a CNC mill...
Might look at this. But, trying to avoid tolerance stacking. I need to maintain the precision of the collets- or it's useless to me.
*sigh*... fitting backplates to chucks and collet systems has been covered 'many many' times on PM. And elsewhere.
Not clear at the moment whom is useless to which if you have not / will not take that rich set of usefulness on-board.
Aya. I have Jacobs 9XX, 5C, 2J, Multisize, and ER 40 on D1-3 arredy.If I didn't already have a Jacobs rubberflex for the nose, (up to 1-1/2" collet capacity) I might well make my own threaded backplate and consider mounting one of these onto it:
1MM DIAMETER ER-4 COLLET CHUCK (391-536) | eBay
easy to make adjus-tru, if desired, as well.
THIS, is exactly what I want. Just was wondering if it's made commercially, as I STATED in my OP.
ER4 Collet Chuck
If you really want it to run true, make it yourself from scratch. Turn the taper while it is mounted on your lathe. Buy the nut and spanner.
allan
This is an excellent suggestion, and not difficult to do. I'm far from a trained machinist and was able to make my own ER-32 collet chuck that screws directly onto the threaded spindle of my 10K. I also made the nut and a couple of spanners for it. As suggested you can also use the nut you have if you thread your chuck to match it. The runout is zilch.
...Didn't ask for an effing lecture. Now, stay the hell out of my thread...
Does anyone know of a source for this? I have an MT3 mount, but want one that'll thread to the spindle nose (for feed-through).
Can't find this animal anywhere.
Or, if you haven't the skill, time, equipment and proper attitude, out shop it.
Notice
