South Bend 10 Heavy Spindle Bearing Wear
Results 1 to 8 of 8
    Sep 2017
    Ohio
    12
    Default South Bend 10 Heavy Spindle Bearing Wear
    I am in the process of restoring my South Bend 10 Heavy when I noticed that my bearings seem quite scored. Are these bearing still serviceable, if not, what are my options?
    Flickr: Page Not Found
    Sep 2010
    moscow,ohio
    4,547
    451
    1354
    believe it or not they will be fine...the most important element is the spindle journals, as long as your spindle is good and free of galled on iron deposits, you will never know the difference.
    Sep 2014
    Arizona
    644
    461
    187
    If your spindle lubrication system is working correctly, the spindle journals never touch these surfaces in operation. Heavier scoring does result in lower off-axis loads before the spindle breaks through the hydrodynamic bearing film, but in a home shop on Heavy 10 I don't think you should lose sleep over it.
    Here's a video clip of my 16" pumping oil via capillary oilers through the bronze sleeves. It's not segmented cast iron like yours, but relies on the same physics and the same oil felt system. I have read that the longitudinal slots in the cast iron bearing headstocks were cut to reduce oil cavitation, but I don't have enough info to back that up.
    Instagram
    It should run fine for many more years, just make sure the felts are clean and the reservoirs are topped up.
    Jul 2008
    South Bend, In
    2,406
    120
    193
    Smile
    Quote Originally Posted by thomasutley View Post
    Instagram
    Kingtutley
    Thanks for the video
    Ted
  5. Likes thomasutley liked this post
    Sep 2017
    Ohio
    12
    Thanks for the quick and informative replies!
    Sep 2010
    moscow,ohio
    4,547
    451
    1354
    BTW- if you are near I have a very nice 10L cast iron base, free for pickup.
    Everything but the motor, leg and chip pan too(for 3.5' bed)
    Sep 2017
    Ohio
    12
    I live just North of Columbus, can you send me pics? I may be interested.
  9. #8
    Sep 2010
    moscow,ohio
    4,547
    451
    1354
    wish I could...chair bound.
    But it is a nice one. I scrapped the lathe but the base was too nice so I have been saving it for anyone that can pick it up.
    PM me for contact info.
