South bend 13 cross feed screw variations
Results 1 to 6 of 6
    Mar 2014
    Maine USA
    38
    21
    Default South bend 13 cross feed screw variations
    In looking at the south bend lathe parts manual, there are two part numbers listed ( 20 and 21 ) but only one (non-taper attachment) pictured which is 20. It is labeled direct reading dial. However there is only one nut listed which is part 56 labeled English threads.
    Can anyone tell me the difference between the screw labeled 20 and the variation listed as 21?
    I am wondering because I bought a used screw on eBay which appears dimensionally correct except it will not screw into my existing cross feed screw brass nut.
    Is one part designated for a direct reading dial and the other for non direct dial? Or is one variation metric?
    Paul
    Mar 2014
    Maine USA
    38
    21
    A little further investigation reveals that the replacement screw I purchased is 8 1/2 tpi while the original is 8 tpi. I used a caliper, in 4 inches the new screw has 34 threads while the original has 32. No wonder it won't thread on! They both measure .625 in thickness and every other aspect appears to be identical.
    Feb 2004
    Indiana, USA
    11
    5
    I am the one that sold Paul the screw. I would also like to know if they used two different threads in the 13" lathe. I checked the screw with a new nut I had and it fit. I have 2 more screws and they also fit the nut. Then I found another nut and they don't fit that one. The nut they fit has a M stamped on the side. Did South Bend make a Metric 13" lathe?
  4. Likes Pmat liked this post
    Jul 2008
    South Bend, In
    2,449
    121
    197
    Quote Originally Posted by hutchwood View Post
    Yes, SBL made metric 13" lathes as well as the 9",10", and 16" (and the shaper)
    The metric components were marked with a "M".
    Ted
  6. Likes Pmat liked this post
  7. #5
    Feb 2004
    Indiana, USA
    11
    5
    Thank you for your help Ted. You learn something new every day.
    Dick
  8. #6
    Mar 2014
    Maine USA
    38
    21
    Like to point out that Dick sent me a refund, very honest decent eBay seller.
    We both learned something.
    Paul
