South Bend 13 restoration - Serial number 80335
Results 1 to 20 of 20
    Jan 2009
    Boulder, Colorado
    12
    8
    Default South Bend 13 restoration - Serial number 80335
    I bought a South Bend lathe at auction. I have wanted a lathe for a long time and the South Bend lathes are terrific.
    The lathe is probably a 1938 model, 13 inch swing and 5 foot long bed. It was cheap but had some real damage. I suspect someone dropped it on the floor since most of the cast iron handles are broken. There's also a medium amount of wear on the V-Ways, you can see a ridge on the front V-way near the spindle. For my skill level this is probably just fine. Otherwise, it is straight and complete. The gears and drive train are in great shape.
    I initially thought I would clean it up a bit and put it into service since I have a big CNC milling machine project I'm in the middle of.
    After looking it over, I decided it would end up being a good lathe and I was worried about the condition of the lubrication systems. Didn't want to run it if the lubrication wasn't working correctly. This lathe uses wool felt wicks to oil and if they get clogged, they don't work. Since it's 80 years old, I thought they might need refreshing.
    I decided to take it completely apart and bring it down to bare metal. Repaint and re-build the whole thing. Plus, that sounded like more fun.
    I've watched 20 hours of you tube videos and there is terrific knowledge and documentation about these lathes. I know just how to proceed. I bought a new felt oiler kit (all the bearings were wet with lube when I took it apart but lots of dirt and debris). I ordered some special welding rod to try and repair the broken handles.
    Now that it's apart, I'm in to purple power, Mr Muscle, Citristrip and lots of buffing.
    What color should I paint it? Hard to tell from the forums what all the different choices look like.
    Erik
    2017-05-25-16.59.29-hdr.jpg2017-05-25-18.06.26.jpg2017-05-27-13.53.39.jpg2017-05-27-13.53.51.jpg2017-05-27-13.54.07.jpg
    Jan 2009
    Boulder, Colorado
    12
    8
    I've spent a couple of weeks on the lathe. Took it all apart and then started stripping parts down to bare metal. The black filler under the paint is REALLY tough! The best method I found for removing it is a needle scaler. Paint stripper takes a number of coats and doesn't well remove the filler.
    Pictures follow:
  3. Likes texasgunsmith liked this post
    Jan 2009
    Boulder, Colorado
    12
    8
    Here are some pictures of the base and legs
    Attached Thumbnails Attached Thumbnails img_0495.jpg   img_0457.jpg   img_0452.jpg   img_0421.jpg   img_0403.jpg
    Jan 2009
    belleville,il
    184
    67
    18
    Keep up the good work. Looks good.
    Feb 2016
    450
    225
    129
    Which paint did you end up choosing ?
    Jan 2009
    Boulder, Colorado
    12
    8
    Quote Originally Posted by texasgunsmith View Post
    I used the paint shown in the attached picture. I got the formulation from someone on this forum, looked at so many I can't remember who.... It's a bit darker/deeper than the standard gray. I like how it looks on the machine.
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Lower Drive Unit
    I've finished with the lower drive unit. This is an old lathe. There are not roller bearings on the lower drive, there are what looks like babbit bearings. They have a keyway slot in them and a brass ring (one of which I broke by driving the shaft through it and replaced with a stainless ring) with wick that gets them wet with oil. The oil escapes the bearing and pours back into the resevroir via channels in the casting. Amazing....
    I went with bright paint for this one. It's in the cabinet so you can't see it and I liked the colors.
    2017-07-17-12.42.45.jpg2017-07-11-21.28.37.jpg2017-07-15-18.38.51.jpg2017-07-15-14.13.42.jpg2017-07-15-18.38.41.jpg
  9. #8
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Main Body
    Here's the completed main body assembly. Nice to be done with the big pieces!
  10. Likes thomasutley liked this post
  11. #9
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Doors
    Motor body doors and the great lubricant and wick kit I got on eBay.
    2017_07_09_lathe_1.jpg2017_07_09_lathe_2.jpg2017_07_10_lathe_1.jpg2017_07_10_lathe_2.jpg2017_07_15_lathe_7.jpg
  12. Likes thomasutley liked this post
  13. #10
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Completed Assembly
    The completed motor assembly installed in the case. Heavy!
  14. Likes thomasutley liked this post
  15. #11
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Cracked handles
    Several handles broken and a cracked pulley. I bought a special nickel welding rod for cast iron but decided to try my MIG first. It worked fine. Lots of pre-heat and I ground a deep relief into the original crack. Welded no problem, if a bit ugly. Ground it down flat, can't tell and seems strong.
    2017_08_03_lathe_1.jpg2017_08_05_lathe_1.jpg2017_08_05_lathe_2.jpg2017_09_10_lathe_6.jpg
  16. Likes thomasutley liked this post
  17. #12
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Headstock
    Here's the headstock and main bearings.
    2017_09_06_lathe_1.jpg2017_09_10_lathe_1.jpg2017_09_10_lathe_2.jpg2017_09_10_lathe_8.jpg
  18. Likes thomasutley liked this post
  19. #13
    Jan 2009
    Boulder, Colorado
    12
    8
    Default Completed Headstock
    Here's the whole thing together.
  20. Likes thomasutley liked this post
  21. #14
    Sep 2014
    Arizona
    684
    486
    210
    Getting close now. Keep it up!
  22. #15
    Jan 2009
    Boulder, Colorado
    12
    8
    Seems like I'm taking forever! Always some other project (or my job) getting in the way of my favored hobbies.
  23. Likes thomasutley liked this post
  24. #16
    Sep 2014
    Arizona
    684
    486
    210
    Quote Originally Posted by eriksalo View Post
    Right there with you. I'm coming up on three years for my resto because of a job move and raising teenagers. Just gotta stay organized and focused and you'll be making chips soon enough. Just enjoy the process along the way, too.
  25. #17
    Aug 2017
    Illinois
    92
    56
    29
    I like that darker grey. The whole thing looks great.
  26. #18
    Mar 2008
    16
    5
    Sent my "Hey boy" to college. Mounted a plastic cement mixing tub under the frame to catch chips. 1x3 channel to support the tub rim.
  27. #19
    Jun 2013
    england-newcastle upon tyne
    701
    124
    152
    Love it better than reading any book-Great job
  28. #20
    Jul 2009
    Munster, In. USA
    2,031
    359
    547
    Spindle journals look nice. I have the '39 edition in baby blue
