A couple of years ago I bought a south bend 13. It wasn't very expensive and at the time I didn't notice that the front spindle bearing cap was a shop made replacement. I've used it that way for a while but noticed that there was too much play (around .012) in the spindle. When I took the shop made cap off there were no shims to remove. Without thinking it all the way through, I bought some bearing caps thinking it would be an easy fix. I am now thinking that the headstock and bearing caps must be machined together. While the new caps go on ok, the alignment pins are not perfectly aligned and it locks the spindle after just a little tightening while the cap is still 1/8 inch up on both sides. I am wondering if removing the alignment pins is a viable option. The existing shop made cap does not have any pins. Any ideas?.
Paul
Paul
