geardoc
Cast Iron
- Aug 8, 2012
I have run into a problem. The local electrical company refuses to upgrade my shop to 3phase, despite the fact it is run through my area and that it runs on lines that run through my property.
The South Bend Fourteen I purchased is the gear head, belt drive version with an electronic speed control. I have been told by someone who owned a few of these lathes that the electronic speed control it is not compatible with a VFD or Rotary Phase Converter. He says that you get very erratic and very inaccurate speed readings off of either VFD or RPC, and that you will eventually burn up the speed control.
I have taken the lathe to a friend's shop that has three phase and we spent quite some time getting it wired up today, and I have found that if the lathe is powered with a steady supply of 3 phase- the speed control works and remains very accurate.
However, powered by an RPC- the speed control was off- the reading on the tachometer on the lathe's control system does get off by quite a bit. So that much is true.
I was told, however, that if I could find a wiring diagram for my lathe, that I might be able to switch the motor over to a 2 or 3 horsepower 220v motor.
I contacted Grizzly to purchase an idler gear for this lathe, and what I got was not an idler gear for my lathe, so I am reticent to trust anything they provide. If anyone owns this lathe and has the wiring diagram for the speed control, or could advise me on how to keep the electronic speed control while converting to a 1phase electric motor, I would be VERY greatful.
I
I
