oldfaithful
- Jan 23, 2017
Hello All,
I've been dealing with an issue on my (approximately 1961) South Bend 16" Lathe, and am wondering if anyone has any experience here they'd be willing to share.
When I bought this lathe, the previous owner had the belt tension so tight that he had to stand on the engagement lever to force it into place. I didn't think this was correct, so I've adjusted the screw to release some of the load required to engage. I'm happier with it now, but in my study of the components (engagement lever, eccentric, knuckle, connecting sleeve, etc.) I've noticed that there must have been a tension spring attached to the connecting sleeve with the exposed pin. There are wear marks where the spring should be, and a worn retaining washer, but no spring. I don't see the corresponding attachment for the other end of the spring either. I'm guessing that the spring failed and the attachment bolt was removed. Does anyone have any pics of these parts, or any info on the design of the spring? Spring rate, length, diameter, load at length...anything? Perhaps a better question is, do I need to replace the spring since it still works without it?
By the way, my lathe doesn't have "Stop Screw E" that KYLIT says should limit the load on the belt by stopping the cradle before it's entire weight is placed on the belt. When I engage the motor, the entire weight of the motor is on the belt and there is no adjustable stop that I can find. There are the 2 adjustable screws on the right (edit: mistakenly stated "left side") of the pedestal that limit the travel of the engagement handle, but that doesn't appear to limit the load applied to the belt. Can anyone explain how to properly adjust this setup?
Thank you!
Thank you!
