South Bend 8'' Lathe info
Results 1 to 19 of 19
    Oct 2009
    wauchula florida U.S.A.
    19
    Default South Bend 8'' Lathe info
    I have a South Bend 8'' Lathe that I have been seaching for toolings for but have only found a few for it I still a need a steady rest most of all but almost any thing else would make me laugh in releif it looks and has been used very little I use it often and like working with it instead of the 9 and 11 that I have does anyone have any info on it in this manner.?
    Johnny in Central Florida
    [email protected]
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    Many of the 8" South Bend lathes were Kits that were built by students. I have never seen one in person. If the bed is the same size as a 9" workshop you could just use a steady for a 9". I have a 10K steady that I use on my 9" model A, and it works fine. Gary P. Hansen
    Feb 2008
    newark DE USA
    1,040
    84
    Default steady rest
    There was a company that made steady rests for any lathe.They send you a form and you make the measurements of the machine.J C Bogeman 602 982 8436
    Oct 2009
    19
    Sorry about not getting back to you guys any faster but I did not expect help this fast as I screw up my notes alot lately
    but thanks for the info I will contact them and I would like more info on any parts or tooling for the Soth Bend 8''
    Johnny
    Jul 2007
    McMinnville Oregon
    1,172
    12
    The 8 Jr. bed is the same bed as the 405 workshop bed casting. SB did however add the rear V way to it when it was used on the 405. The tool makers lathe or the 20 series lathe bed is the same bed as used on the 415 workshop and later models of this lathe. Yes you could put a 9 inch workshop steady rest on a 8 Jr. but your going to be 1/2 inch to tall and will have a difficult time centering your work piece.
    Turk
    Quote Originally Posted by garyphansen View Post
    Jul 2007
    McMinnville Oregon
    1,172
    12
    I have a book on constructing the kit 8 inch lathe SB offered. In no way is it anything like the 8 Jr. Garry
    Apr 2007
    Minneapolis, MN
    1,292
    68
    232
    Quote Originally Posted by Dennis Turk View Post
    Dennis is right.
    I have one of the 8" "kit" lathes.
    Rob
    Oct 2009
    19
    Default 8" South Bend
    I hope you guys keep on talking about this Lathe the more talk the more info
    Johnny
    Oct 2009
    19
    Quote Originally Posted by jlelandthomas View Post
    Johnny
    {I have the 9" also and it does not fit at all and improvising a half inch would be out of the picture and render it almost usless for me}
    Feb 2004
    Traverse City, MI
    3,264
    61
    102
    Turk: He just said he had a 8" South Bend. I didn't see any thing about it being a 8" JR and up until now I do not remember hearing about an 8" JR. As for using a 9" steady rest on a 8" lathe all I can say is that I have been using a 10K steady on my 9" model A for years and have not had any problems. Of course the Steady would have a slightly less capacity than if used on a 10K lathe. Gary P. Hansen
  11. #11
    Oct 2009
    19
    For you fellows info South Bend did make an 8" lathe and here are the model and bed numbers 406-ZF 8" x 42" Bed Number is 51289 I do not know the year but a good guess is 1932 I would like to know the real year and anything else . Mine also has a builders brass tag that say's A.C.COLBY Manufacturing Co. 183 centre street New York City
    Johnny
  12. #12
    Jul 2007
    McMinnville Oregon
    1,172
    12
    John the 1931 8 Jr. does not have screw in lead screw mounts on the saddle or the compound. The lead screws are assembled into the saddle using a sleeve and a tapered pin. Same for the compound. I will say they are a bitch to take apart and re-assemble. In 1932 SB switched to the more conventional lead screw mounting using a screw in bushing on both the saddle and compound. So if you have screw in bushings the lathe was built in 1932 or 33. Also the 1931 lathes were black and the 32 and 33 lathes were the dark gray with the blue tint to it.
    Turk
    Johnny
  13. #13
    Oct 2009
    19
    Default 8" South Bend LATHE
    I guess the Ac Colby Company in New York built it from the kit as you said Dennis I didn't know it was a kit . I couldn't understand the nice brass plate with The Colby Manufacturer in New York I thought they were built by South Bend in South Bend .I wish that I had some paper work on it now I think I want to clean it up paint up and put it up for show like my engines as it kind of special now that I know more about it.
    Johnny
  14. #14
    Jul 2007
    McMinnville Oregon
    1,172
    12
    Hi John
    The 8 Jr. was never sold as a kit it was always a complete lathe like all the other models they sold. AC colby was a very active seller of SB equipment. I have two lathes with the AC colby tag on them and we have seen many more. I also have a picture of the AC colby store front that was taken in the mid 30's we think. I will send you a copy in a private email.
    Turk
    Johnny
  15. #15
    Oct 2009
    19
    I am glad I have all that straightened out now.About the two Lathes and I really like the picture of A.C. Colby Machines Sales
    Johnny
  16. #16
    Oct 2009
    19
    You all know I am really proud of all the help that I have received and I did get a steady rest in the mail today from Mr Turk I like putting stuff together the way it should be and not using after market stuff unless it the last draw or that is the way it is .These The 8" inch South Bend lathe is really a good lathe .I have made engine parts and built kit engines of all sorts with it now I can do more if I want now that I have more tooling for it .I have a 9C and 12 also a Clark 7" I am thinking about selling the 7" Clark to make room and find a small milling Machine the older the better as long as it is all their for me finish or repair If some one has one or knows of one please yell at me
    Johnny
  17. #17
    Jul 2007
    McMinnville Oregon
    1,172
    12
    Just a side note to this posting.
    This week I purchased a second 8 Jr. This lathe is only the second 8 Jr. found with the overhead drive like the one you see on my 8 Jr. on Tony's site. The only other lathe to use this drive was the 1934 Tool Makers 9 inch. I have a really nice example of this 20 series lathe and its equipped with full floor legs as well as the only known taper attachment seen on a Tool Makers lathe.
    The plan for 8 Jr. I just purchased is to use the overhead drive on the Tool Makers lathe as this addition of the drive will make a very rare lathe. Seams I have been collecting a number of 8 Jr. lathes as well as extra parts that will have to be disposed of. For one I have an extra head stock that is near perfect and would let it go to someone that needs a replacement. I also have an extra tail stock and some other parts. With the delivery of the new 8 Jr. I will have even more parts. If the lathe from California is a good one I may try and sell it complete as there are very few lathes for sale in the Northwest. For you that don't know what a Tool Makers 9 inch lathe looks like its exactly the same as an 8 Jr. one 20% larger. Side by side its hard to tell the difference between the two models.
    Turk
  18. #18
    May 2006
    Austin, TX, USA
    225
    If you have a steady rest, I'd love to take it off your hands.
  19. #19
    Jul 2007
    McMinnville Oregon
    1,172
    12
    Sorry John got my only spare steady rest and the new 8 Jr. does not have one with it.
    Dennis
    Quote Originally Posted by Lee Owens View Post
