South Bend 9" Model A taper attachment?
alan speyrer
Stainless
Feb 15, 2009
Shallowater
After much searching, did south bend make a taper attachment for there model 9 A lathe? Seems there are lots of taper attachments for 10 and 13 inch lathe SBL, can't find any for a 9 inch lathe.
If you are not all for looks just build your own. I have some plans of different ones. I made a simple one for my 10K for 22 bucks and it works just fine...Bob
After looking at a couple different plans for these, this looks like a nice simple design. There was one set of plans from an older magazine reprint the used two rods, and I never understood why it needed to be more complicated than a single rod design like your's. After looking at this pic, I'd really like to make what you've got.
A few of questions for you...
What's the diameter of the rod you used? (Assuming it needs to be pretty stiff.)
Do you have any ajdustability on the wheels/bearings?
Anything you'd do differently?
Jack
Look also for 10K
South Bend 9" Model A taper attachment is the same for the 10K
I have put mind on both 9A and 10K
Works great is use from time to time I bought it back 1972 new still looks new to day
Jack
My rod is 7/8" i would change to 1" but my wheels were already made up.
The wheels are adjusted to fit tight on the bar with the little cam followers.
I prob would use 1" sq bar on my next one with square groove parts...Bob
Hi, I realize this is an older post, but can you send me plans to make a taper attachment form my SB 9A? It would be greatly appreciated, Thank you, - Carey
