I’ve been digging for information on our lathe in order to repair it. I am not an expert in lathe repair, but do need to get this one running.
The issue started when we were doing a run of drilling and tapping for some leg slugs to accept leveling feet. At the end of the run, the lathe started to loose power, even when just centering. So, I stopped the production of the slug. Upon closer look/feel, when I tried turning the chuck manually it felt like it was sticking. I flushed the spindle bearings with kerosene, and filled back up with spindle oil. Initially it sounded as those it was running better than ever. Really humming. Then, the next morning I came in to get it running before my guys arrived, and again, it was the same issue. I’m using a very light spindle oil as recommended in the literature from south bend that I have found online. I did note when draining and flushing the bearings that there seems to be no wicks where I was expecting them.
What else might you recommend for getting it running again. It soon will become a problem if I can’t find a solution.
Thank you so much for any assistance you can offer.
