south bend 9'' restoring prodject
Results 1 to 15 of 15
    Nov 2017
    Iowa
    7
    Default south bend 9'' restoring prodject
    hello
    new to this site i have a south bend lathe that has a catalog # 22zb
    and a s/n 48061-A and im wanting to restore it anyone have any info on it or can tell
    me where to find any i believe its made in 1931 but not sure any help would be greatly
    appreciated
    thank you
    Jul 2004
    Houston, TX USA
    26,785
    Welcome to forum. Here is the related catalog if needed.
    http://www.wswells.com/data/catalog/...Cat_No.22C.pdf
    Thanks to Mr. Wells for the scan
    Sep 2010
    moscow,ohio
    4,049
    403
    1141
    Yes, 1931...got pics??
    Nov 2017
    Iowa
    7
    not yet going to clean it up alittle and then ill post some
    Nov 2017
    Iowa
    7
    thank you does anyone know what the letters zb on the end of the catalog # mean and the letter A at the end of the serial number mean
    Sep 2010
    moscow,ohio
    4,049
    403
    1141
    Z=3.5 ft bed
    B= bench model
    Nov 2017
    Iowa
    7
    ok thank so much the one i have has a counter shaft that sits flat on the table behind the lathe and the motor sits behind that i was looking to change that to shortin it up a bit so i can get mounted on a bench that is much narrower maybe 30''
    Nov 2017
    Iowa
    7
    does anyone know where i can get a motor mount i was interested in the one that is hinged on the bottom and sits at an angle with the motor mounting under the counter shaft
    and i beleive on that one it looks like the weight of the mount is the tentionor too
    Aug 2013
    715
    412
    194
    Ebay has these mounts all the time. There is a turnbuckle that tightens the belt. Weight only will allow the motor and mount to shake all over the place! (My Enco does that, even with a spring to help)
    My 9" has a shortened set of turnbuckle rods, so it does fit on a 30" desk top.
    Note, if you have a taper attachment, it bangs up against the motor (I have an underdrive the taper attachment belongs to. One reason why it is not on my horizontal drive.)
    John
    Sep 2010
    moscow,ohio
    4,049
    403
    1141
    Note that the countershaft pulley HAS to be the mate to your spindle pulley, so check the size of the steps to see if it matches your original.
    If not you will need to transfer your original into the later countershaft otherwise you will be adjusting the tension for each step.
  11. #11
    Nov 2017
    Iowa
    7
    thank you comstockfriend
  12. #12
    Nov 2017
    Iowa
    7
    does the letter A on the end of the sbl s/n 48061-A mean its a model A
  13. #13
    Aug 2013
    715
    412
    194
    Model A's have gear box and power longitudinal and power cross feeds.
    Model B's have change gears and power longitudinal and power cross feeds.
    Model C's have change gears and use the lead screw for all power longitudinal feed and threading, no power cross feed.
    See http://www.lathes.co.uk/southbend/index.html
    and http://www.wswells.com/
    to start your South Bend journey...
    John
  14. #14
    Aug 2013
    715
    412
    194
    And FrankenLathes will have any combination of the above!
  15. #15
    Sep 2010
    moscow,ohio
    4,049
    403
    1141
    I am not sure what the A means in your case as the lathe predates the ABC designations...it is certainly not a model A
