mbouchpcp
- Aug 23, 2015
- Phoenix (East Valley)
I have a new to me SB 9A (1947 model year) and never operated a lathe till I got this machine from a friend.
I needed to cut some soft steel. I found that high gear was too fast for the task and engaged the back gear. I pulled the bull gear lock engagement pin out, moved the back gear lever on the the left side of the back gear shaft to engage it, pushed the bull gear pin back into place, and went on to cut some metal.
I then tried to reverse the back gear engagement process without success. The back gear is still engaged and I cannot move the left side lever to disengage the back gear shaft. Moreover, the motor does not turn the spindle when the bull gear pin is pushed in. With the pin in the spindle will **only turn** via lots of muscle power and a breaker bar in the jaws of the chuck. The motor turns the spindle in high gear **without issue** when the bull gear pin is pulled out, but that is not how the lathe was working when I first got it.
I removed the left Quill Gear Guard and right Bull Gear Guard covers. This revealed that the back gear shaft is eccentric to the mounts on either side. Also the gears on the left side and right side of the back shaft are engaged with the opposite gears of the spindle.
Suggestions on how to proceed would be appreciated.
Please note that while other high schoolers were in shop class, I was busing tables in a restaurant between classes to pay my high school tuition. My experience since then has been everything but mechanical in nature. In fact, I still mouth "righty tighty and lefty loosy" when turning bolts. Hence, please keep my mechanical impairment in mind if you wish to provide any badly needed guidance.
Thank you.
Mark B.
Late note. A request for pictures was made. Here you go.
Later Note:
Special thanks to John Evans and his thoughts regarding the back gear bushings. It focused my search and I found South Bend Maintenance Form # 2000 dated 10-1-65 titled "Back Gear and Eccentric Shaft". The one page document has four sections titled I. To Disassemble, II. To Reassemble, III. Adjusting Back Gears and IV. Oiling.
I am going to cross my fingers and try to adjust the back gears using Section III directions. Should that prove unsuccessful, I will dissemble, reassemble and try adjusting again. if that fails, I guess I'll get a bigger hammer and longer breaker bar.
The work will not take place till late Saturday or early Sunday so anyone with thoughts, suggestions, or warnings should feel free to jump in. Something like this may be old hat to most of the folks here, but it is rocket science to me.
Thanks to all who have responded so far. I've learned something from each response.
Saturday afternoon progress
I removed the left side hex nut and set screw and right side C screw, spring and shoe. The eccentric bushing taper pin called for within the South Bend Form 2000 back gear and eccentric shaft illustration was missing.
Quill gear and eccentric shaft fell away from the spindle at this point. In other words, nothing is jammed up now.
I'll reassemble and adjust the back gears once I find a replacement taper pin from McMaster Carr, Enco, or preferably some place local.
Not looking forward to the adjustment as the instructions are terse.
Best wishes to all.
Thank you.
Mark B.
Later Note:
Best wishes to all.
