Norsksea
- Dec 10, 2007
- East Coast
Hi
I have been searching around and read a lot of good information here about South Bends.
The picture below is my South Bend 9” model C with a 48" bed. I am the 2nd owner of this lathe, which is in great shape because it was and still is only a hobby lathe. I never liked changing gears for the power feed and never used them.
I just bought a 42" Light Ten with quick change but it has .018 wear groove in the bed. It was well-used lathe and I can’t use this lathe as is. The good news for me is that the parts from these two lathes are interchangeable. I am using my 48” bed and cross feed from my 9C and the 10K headstock, QC gearbox, cross feed apron and tailstock. I had to use the cross feed screw from the 10K because of the gear on the shaft. It fit fine in my 9C saddle, which is identical to the 10k and I get to upgrade to the direct reading larger dials from the 10K. I removed the play in the cross feed dial and used my compound rest screw with the larger dial. I needed to use the 10K compound swivel because it is 1/2 higher than my 9C counterpart. I did use my 9C cross feed and compound screw nuts that are in better shape.
The only real modifications to this lathe are that I need to do is;
Adding the extra hole in the bed for the quick-change housing.
2 holes for the feed screw support because of the 42” screw on a 48” bed.
Fit the 10K bed feet to my 48” bed (different bolt pattern) for the extra clearance height needed for the quick-change levers.
This is as far as I have gotten with my conversion before having to go on a business trip.
Frank
Frank
