bradjacob
Titanium
- Nov 18, 2008
- Easton, PA
I ordered new bearings for my South Bend drill press. I ordered them from Maryann at Emerson Bearings. The whole set of 4 brand-new bearings (shipped) was $29 bucks. It took about 30 minutes total to do the job - and was worth every penny.
The original spindle bearings are New Departure: 88016
The original pulley bearings are New Departure: 88505
First, I removed the belt-guard and front belt.
Then remove the small setscrew in the front of the head.
The front pulley - it should lift right out.
Then, using a "hook spanner" wrench, I unscrewed the locking nut.
** WARNING - these are left hand threads!
You'll need to unscrew the two(2) setscrews inside the pulley grooves, in order to press out the main shaft from the pulley.
Once pressed, I notices that the setscrew created a burr that dragged along and gouged the inside of the pulley.
Here's the raised bur.
To prevent this from happening again, I filed down the bur and then stoned it smooth.
I then pressed out the old bearings (sorry, I don't a photo of doing that, but it's pretty straight forward).
Here's the front pulley fully disassembled
